Freewing Su35 control surface throws
  • Jpahemi1
    • Oct 2016
    • 68
    • Washington Michigan
    Can someone recommend a good starting spot for both high and low rates for the primary flight control surfaces on the Su. I'm not a 3D flyer but I'd like to start out with some safe settings and increase those with experience. I searched the manual but couldn't find any recommended settings.
    thanks
    john
  • Arcangel
    • Jun 2016
    • 85
    • 29 palms CA, north of Moss Eisley and just this side of Anchor-head.
    I'm not familiar with the FreeWing SU-35, but I did check out it's manual on-line and I see your point. I would suggest you download the manual for the FreeWing 90mm F-18 Super Hornet v.2 and use the recommended settings from there as a starting point. The airframes are similar enough in size that they might be closely compatible to each other for flight characteristics. I'd stick with the stated incidence setting from the SU-35 manual though. As for the TV..... that's all up to you and your transmitter manual.
    I had a bitch of a time setting up the TV on my Hornet but it does work and looks cool.
    • Jpahemi1
      • Oct 2016
      • 68
      Thanks arcangel. Sounds like you might be a Mass Effect fan
      • Jpahemi1
        • Oct 2016
        • 68
        Arcangel
        i checked out the F-18. Those settings do sound like a good starting point.
        thanks again
        john
