Focke Wulf light info
  • Hippie 64
    • Feb 2014
    • 1049
    • Gaffney , S.C.
    First off Happy Thanksgiving to MRC and all my Forum friends !!!!!
    I purchased the Freewing light board that is used in the Focke Wulf 190 1120mm .I plan to use it another plane.  What I need is the pin layout and hook up info . The board comes with no paper work and I'm guessing its in the manual . Anyone have that info?????
    Bryan
    But Crashing is Landing
  • Lon
    • Jul 2014
    • 1202
    • Miles, Iowa
    RE: Focke Wulf light info
    Bryan,
    I'm maybe not much help, but, I've had to deal with the light control on my Freewing P-51. There is a pdf manual for that light control there in the support tab. Looking at the control you have, thinking the plugging in of the wire leads is the same thing, only different :P (if that makes sense) Thinking you can figure it out by trial and error.  I know I experimented around with my controller(plugging here, then there). If it's like the P-51 , first set of plugs will be for the landing lights, second set to have nav lights on, and third set to have nav lights flash.  Good luck!
    Lon
    Lon
    • Hippie 64
      • Feb 2014
      • 1049
      • Gaffney , S.C.
      Thanks Lon . I went to the Focke Wulf and it was there !
      • Hippie 64
        • Feb 2014
        • 1049
        • Gaffney , S.C.
        I've looked at the book and it shows strobe pins on the board and just continuous light pins but I've tried both and I can't strobes to flash . Tried all the pins and adjusting the pot for speed but nothing just solid lit . Do I need certain type of light , I'm using ones that came with it ??
        • Lon
          • Jul 2014
          • 1202
          • Miles, Iowa
          Originally posted by Hippie 64,    hmm...got me scratching my  head with a frown on this.......
          Lon
          • Hippie 64
            • Feb 2014
            • 1049
            • Gaffney , S.C.
            It doesn't really matter I bought to use in another plane but would like to add in clear for strobes
