Tech One Swift
  • Robert toth
    Old Man
    • 5
    Tech One Swift
    3S battery size? prop size? room for 1800 mah
    • 8814
    If you go to the product page and look at the spare parts and overview pages, it tells you all of this. It's supposed to take a 1300mah battery. As for room for an 1800, the plane can always be modded (if necessary) to accommodate it and adjust for balance.
    • Robert toth
      Old Man
      • 5
      I read that info. I have 1500 mah in a tech one Edge 540 1000mm and it is tail heavy, Needed to add weight to balance. Sometimes it is just easier to add a larger battery. Flies ok. But Swift has a larger motor and I presume it needs larger battery in the 1800mah range. I was just curious if anyone set up the swift with an 1800 mah battery and how it balanced, since I have to buy some new batteries. Thank you for pointing out the obvious
        • 8814
        Perhaps that's what you should have asked. The way you worded your question is the way I answered it. Why would you "presume" it needs a larger battery when the specs indicate what it's supposed to take? Sorry but if you don't appreciate help for what you asked, I won't lend any more help to you. I have way better things to do with my time. You have a great day and if I accidentally infiltrate one of your future threads just remind me to butt out.
        • Robert toth
          Old Man
          • 5
          Your picture describes everything. Thank you for taking out time to give me a helping hand
