Flying wing
  • doctormike
    HobbySquawk Moderator
    • Oct 2013
    • 1260
    • Santa Fe NM
    Flying wing
    I'm designing a BOT style flying wing. NO vertical stabs. If she flies as well as she looks... what a beauty! Doc
  • fhhuber
    • Aug 2015
    • 1476
    The easiest way to avoid needing veritcal stab is to provide ample sweep-back. This acts somewhat like dihedral and vertical stabilizer.
    Then you'll want some form of controlled drag at the wingtips for yaw control.
    • doctormike
      • Oct 2013
      • 1260
      • Santa Fe NM
      I'm using sweep as well as dihedral just like the Horton gliders. An airfoil with a slight upward turned trailing edge (reflex) and elevons on the outer part of the wing only, are important for stability. Also washout can be difficult (if not impossible) on a folded foamboard wing, so extra reflex on the outer 3" of the elevons will help reduce tip stall tendencies and take the place of washout. I hope all this research pays off! Doc
        That's why I'm waiting til I get a 3d printer to continue my design. Gonna print the ribs out
        • doctormike
          • Oct 2013
          • 1260
          • Santa Fe NM
          Let us know how that works out. I just finished my BOT flying wing airframe. (About $4 in materials) Now for the expensive part, electrics. It's 2 meters. If this flies I'm going to build a 3 meter wing, either BOT style or HO IV. Doc
            Nice I think it should do well. Just setting the battery always was the PITA part. To get that critical cg point exact. Uuuugh.
            • doctormike
              • Oct 2013
              • 1260
              • Santa Fe NM
              Yeah, battery placement in the wings I've built is a problem. CG is really sensitive in these things! Doc
                Yes, that's why I'm looking to the 3d printer route, I'm hoping to have a solid solution for the battery placement that I can first move around, then epoxy in when I find the perfect place. I think that will be my best chance of getting this right this time.
                • Beeg
                  • 1335
                  • Texas
                  doctormike, Don't know if you've flown your wing yet but I got back from the Horizon Hobby Aerotow two weeks and a guy built and flew this beautiful wing on it's maiden flight that flew very well.
                  video https://www.flickr.com/photos/422200...7698096661605/
