FMS 1450mm P-40 maiden
  • Loneflier
    • Aug 2013
    • 603
    • Huntsville, AL
    Hello All,
    Well, I finally got the maiden flight in for my P-40. It was a good bit windier than I would have liked, but since I was at the field, and I had flown both my PZ Corsair S, and the Dynam C-188, I decided it was time to get the Warhawk in the air. The wind started out at only about 5mph, but kept increasing the whole time I was there, and by the time I was flying the P-40, the gusts were 15mph+, probably a good bit more up 100 feet or so. Take off was smooth, not a whole lot of rudder correction was needed, and the actual roll was pretty short, but that was probably due to the 5-10mph headwind too. I left everything on high rates for the first flight, especially since I wasn't sure how much down force I would need on take off. As it turns out, not much at all. I won't say this was the easiest maiden ever, but certainly not the worst either. I had the CG set right at 70-75mm and the plane penetrated the wind well, but gusts hitting it during turns would really rock the wings, and I had to keep more power on than normal just to counter the effects of the wind. Very little trim was required, but again, with all the wind, it was difficult to tell what the plane was doing at times. I never attempted to stall it due to the conditions, but I did manage some nice loops and rolls. She really does look good in the air, and seems to have good power. I was flying with a 2600mAH 35C 4 cell and my timer was set to 5 minutes. After about 4 minutes, I started trying to make some lower, landing like passes to practice brining it in, but the wind kept bouncing it around, and I ended up doing many "go arounds". I never noticed any stalls trying to start, but again, I would really pour on the coals before turning against the wind for the go around. I did notice that this plane loves to glide! It simply did not want to come down. I finally added just a touch of flaps on my last approach, and it would come down to maybe a foot over the grass, and the wind would kick up and she would just float. I finally got it to touch down after another 50 yards or so, and all was pretty good. The glue used for one of the retracts was not super solid, and the taller grass knocked it loose, but that was an easy fix with a bit of epoxy once I got home.
    So, overall, I think it will be a good flying plane, but I really should have waited for a calmer day to try the maiden flight. It handled fine at altitude, and I think it will be much smoother flying on low rates. Anyway, it is down in one piece, the maiden is completed, and I am hoping for better weather soon to really try it out. The 5 minutes set seems about right, I went just a bit a over with all the landing attempts, and still had 35% capacity left in the battery.
    This was my first flight with one of the 1450mm FMS warbirds, and I am thinking there will likely be more in the future!
    • 7405
    RE: FMS 1450mm P-40 maiden
    Great to hear Lone!
    I tried the same thing last Thursday, but the wind was too strong for Pandora One, couldn't get her to swing into the wind for final.  Got her down in one piecealthough I broke a prop on her.  First one since her fiery crash last Spring!  Pretty good reputation all  in all, I should have known better.
    Anyway, great to hear that the P40 flew so well, seems that everyone flying the 1450 scale FMS planes are pleased with them.  Looking forward to better weather to get my Mustangs into the air
    • Loneflier
      • Aug 2013
      • 603
      • Huntsville, AL
      Thanks G56,
      It seems there is a bit more to the story now. I got home, fixed the gear, and went to plug in the battery to make sure everything cycled OK, and all I could get was a single, slow, repeating beep from the ESC. I could not link my receiver to the plane. I did some trouble shooting, and have narrowed the issue down to the landing gear. If I unplug the gear from the rx, I can get everything else to work, but when I plug in the gear, the light on the receiver goes out and everything is dead.
      I am puzzled. The gear simply popped out from the glue joint in the tall grass, and the plane was barely moving when it happened. All I can figure is that perhaps one of the wires has been pulled loose somehow. I had to put in a new rx to get things to work, is it possible that somehow my original rx was damaged by some kind of overload or something? I am not any kind of an electrical guru, so I am hoping someone on the forum has run into this and can help.
      I did contact MRC directly with a message, but late Sunday afternoon, it will likely be Monday before I hear from them.
      • Loneflier
        • Aug 2013
        • 603
        • Huntsville, AL
        Hi Starcop,
        I have the CG set right around 70-75mm on my P40. I was pretty happy with the first flight, but I am disappointed with it following the landing. I set it down pretty well on the mains, but due to the long glidepath, it rolled into taller grass while still moving along quickly. The plastic that the retracts bolt into had not been properly glued by FMS, and as a result, popped out dragging the right gear. (The factory applied the glue over paint, and when the joint came under some load, the paint pulled away from the foam, along with the entire right retract.) Somehow the pull on the wire created a short that caused the ESC to fail. I did talk to Alpha at MRC, but because I've had this kit for over 30 days, the warranty for the ESC had expired, and I have to buy a new ESC and retract now. I will go ahead and fix it, but the whole thing kind of soured my enthusiasm for this plane.
        Glad yours is going strong still. I hope to get mine back in the air soon for its second flight!
