Can’t figure out from instructions where to connect tail light wire to so it works, it has no harness attached.
Dynam Skytrainer 182 tail light connection
I have this same airplane and I had to get a light controller board that MRC usto sell to get all the lights to work. However the stock lights are not that bright. I ended up having to replace all the lights with brighter ones except for the tail light that I left stock and it was hard to see once the pane was in the air. But I suggest just getting this complete kit that MRC now sells and replacing all the lights with it. It is fairly easy to do on the Skytrainer since the wings already have the channels to run the wires through and the kit the lights from the kit simply plug into the controller box.
I would not bother connecting the stock LED's on the top of the middle of the wing either. They are not that bight anyways.
