RE: Freewing CTLS Fligt Design
The maiden was quick. I thought the prop had to be on backwards with needing almost full power to get up any altitude...
http://youtu.be/FOSS_a7iaDI
[hr]
Second flight wasn't as good. With a prop strike after hitting a tiny pebble before lift off, then the resulting "endo", then a flip over with busted prop. Plastic horn attached to metal gear servo that controls the front gear direction, slipped and turned the wheel. Then the front gear plate where the screws fasten, cracked in one corner... With the limited clearance of the 9" prop, I installed a three blade 8.5".
Though I doubt that will help with the lack of power that it seemed to have. I think the pitch is 7.
[hr]
