Nice airplane and first flight went well but the retracts don't retract fully in flight. Work fine on the ground. Sequencer and light control worked fine but the light leads were too short to connect while attaching wing. I used the FMS extension/plug ins but found they will not make taking the wing on and off any easier. I ended up using about four extra servo extension leads and will be looking to get extensions for the light leads.. Still had the muddle thru rats nest of wires that I don't choose to do every time I take the plane out.
While setting up the control throws the tailwheel door servo ran away and started making this constant grinding noise that resulted in a frozen servo that will not move at all. I assume the geartrain is ruined. Have disconnected it until I can give MRC a call about a replacement.
In the battery compartment there was a strap that was designed for the sound battery but not useful for the flight pack and had to supply one that was long enough.
Anybody got a fix for the retracts sagging? They hang down about an inch at least and is very noticeable. Cut the flight short as I didn't know if they were a constant drain on the battery.
Thanks,
Rich
Thanks,
Rich
