Just curious if anyone has had the issue where it seems like the speed controller cuts the throttle at times and it gives this repetitive beep beep. ? Not sure why this happens every once and a while.
FMS Yak 54 1300mm
RE: FMS Yak 54 1300mm
Try recalibrating your throttle, mine was similar out of the boxOriginally posted by EddieFC02Just curious if anyone has had the issue where it seems like the speed controller cuts the throttle at times and it gives this repetitive beep beep. ? Not sure why this happens every once and a while.
CT
I do . But it still happens from time to time. Maybe I should recalibrate at the start of each flight to be safe. A little unnerving when you are attempting 3d aerobatic maneuvers to know the throttle may cut off at any given time. Otherwise this plane would be the best foamy 3d out there. it handles maneuvers so well but not for beginners or even really intermediates for that matter.Originally posted by CTTry recalibrating your throttle, mine was similar out of the boxOriginally posted by EddieFC02Just curious if anyone has had the issue where it seems like the speed controller cuts the throttle at times and it gives this repetitive beep beep. ? Not sure why this happens every once and a while.
CT
Yeah, the Yak 54 is one of the best 3d flyers, be careful not to land very hard or the fuse will break in half at the tail, its weak point. You shouldnt have to recalibrate every flight, may be some glitch with the ESC, although I have never had a bad one from Eflite.Originally posted by EddieFC02I do . But it still happens from time to time. Maybe I should recalibrate at the start of each flight to be safe. A little unnerving when you are attempting 3d aerobatic maneuvers to know the throttle may cut off at any given time. Otherwise this plane would be the best foamy 3d out there. it handles maneuvers so well but not for beginners or even really intermediates for that matter.Originally posted by CTTry recalibrating your throttle, mine was similar out of the boxOriginally posted by EddieFC02Just curious if anyone has had the issue where it seems like the speed controller cuts the throttle at times and it gives this repetitive beep beep. ? Not sure why this happens every once and a while.
CT
