Eflite Carbon z T28 repaint
Hey Alpha is that you in the F-14 pic. I've been wanting to do the 80mm F-5 in that paint scheme, how did you do it. Did you just start with your color base cost and just panel it out with post a notes for the other colors.. -
Man that's looking awesome. Got a couple of projects first but I've got to give my Carbon Z a paint job. Callie ( as always) has the graphics). I got this thing for camo schemes.
Mike1 PhotoLeave a comment:
It's easy to work with and I'd suggest some testing on some scrap parts till ya get the hang of it.
MikeLeave a comment:
Thanks Mike , I will give that a try today.
Hope this works , because it has slow down everything I'm doing .
I just want to get to the detailing part soon, so I can see it all come together before the weather gets bad.Leave a comment:
Sorry, no I did not weigh them before starting.
No primer coat this time.
Used the spray on Minwax and not the brush on Minwax.
Lots of wet sanding between coats.
Less paint sprayed on rear and bottom of the elevators, wings and the bottom of the plane ,lessons learned from the Blue Angels plane.
If you remember from my flight video of the Blue Angels, I didn't notice any performance difference in flight after painting, just the CG moved from my normal spot. Had to move the battery forward.
I really like where this white one is going! Curious if you weighed them before and after paint?Leave a comment:
