Eflite Carbon z T28 repaint
  • Apache Jets
    Hey Alpha is that you in the F-14 pic. I've been wanting to do the 80mm F-5 in that paint scheme, how did you do it. Did you just start with your color base cost and just panel it out with post a notes for the other colors..
  • t33jetman
  • t33jetman
    Originally posted by MikeT
    Man that's looking awesome. Got a couple of projects first but I've got to give my Carbon Z a paint job. Callie ( as always) has the graphics). I got this thing for camo schemes.
    Mike
    Very nice choice ,should look good in the air.
  • MikeT
    Mike
  • t33jetman
    That's looking really good!
  • t33jetman
    Thank you for your help on the low tac paper mask. You saved me so much stress.
    I can't believe I finished the hard part in one night. Not because it is easy, but I chose to do the scalps because it was hard. I'm using the Blue Angels wings as a mockup till I do the TB wings.
  • t33jetman
    It's easy to work with and I'd suggest some testing on some scrap parts till ya get the hang of it.
    Mike
    I really do appreciate everybody's help and ideas on this because this was bugging me as to how I was going to get around some of these tight Parts because there's some chrome paint that has to go on also
  • MikeT
    Originally posted by t33jetman
    Thanks Mike , I will give that a try today.
    Hope this works , because it has slow down everything I'm doing .
    I just want to get to the detailing part soon, so I can see it all come together before the weather gets bad.
    Mike
    Clear low-tac paper is a great recommendation, Mike! I've used regular Dollar Store Post-Its with similar success. That's how I masked my F-14.
  • t33jetman
    Try Clear low tack self paper ( I get it at Wally World ). That's how I masked my A-10
    Mike
  • MikeT
    This is the part I hate, and will take some masking skill not to bleed over. Click image for larger version
    Mike
  • t33jetman
    How are you doing your rivets?
    A brass tube clamped into my dremel tool.
  • t33jetman
    Very cool! Cant wait to see them side by side ready to go.
  • MikeT
    Looking good.
    Mike
  • t33jetman
    Made my own paint mask for the nose and rudder. Forgot to take pictures of rudder before the paint went on.
    I really liked the down draft from the fan when paint the nose and elevators. That was so cool , that I'm gonna have to make a table with the fans pointing down in it.
    Click image for larger version  Name:	20181007_125837.jpg Views:	1 Size:	112.1 KB ID:	155539Click image for larger version  Name:	20181007_125848.jpg Views:	1 Size:	84.9 KB ID:	155540Click image for larger version  Name:	20181007_184759.jpg Views:	1 Size:	134.0 KB ID:	155541
  • t33jetman
    I really like where this white one is going! Curious if you weighed them before and after paint?
    Sorry, no I did not weigh them before starting.
    No primer coat this time.
    Used the spray on Minwax and not the brush on Minwax.
    Lots of wet sanding between coats.
    Less paint sprayed on rear and bottom of the elevators, wings and the bottom of the plane ,lessons learned from the Blue Angels plane.
    If you remember from my flight video of the Blue Angels, I didn't notice any performance difference in flight after painting, just the CG moved from my normal spot. Had to move the battery forward.
    Click image for larger version  Name:	20181008_204655.jpg Views:	1 Size:	111.9 KB ID:	155535
