beautiful nice work, yet cruel and unusual punishment to some ;)
TiredIronGRB's 2285mm OV-10 Bronco Build
The OV-10’s wing is square not swept, so MAC is the same over the entire span. Where your finger is in the picture equates to 40% of MAC. That is indeed an aft cg that will most likely result in a crash. The cord of your wing appears to be around 14 inches so
14 x 20% = 2.8 inches ...... 14 x 25% = 3.5 inches ....... 14 x 30% = 4.2 inches .....
I’d get the cg forward to around 3.5 inches aft of the leading edge provided your cord is 14 inches. You can do an exact measurement of your cord and fine tune that.
Yes, 15" so at 25% it's 3.75" which looks about right to me for it to be just a tad nose heavy.Originally posted by Ole-Timer View PostThe OV-10’s wing is square not swept, so MAC is the same over the entire span. Where your finger is in the picture equates to 40% of MAC. That is indeed an aft cg that will most likely result in a crash. The cord of your wing appears to be around 14 inches so
Full scale 58 ft wingspan.Originally posted by TiredIronGRB View PostI could add a pilot to add some nose weight, what scale would you guys say...1/6?
What wingspan for the model?
Appx 90 inches...
That's 1/7.73 so I'd look at 1/8 scale pilot figuresFF gliders and rubber power since 1966, CL 1970-1990, RC since 1975.
Yes, 90" windspan.Originally posted by fhhuber View Post
Appx 90 inches...
Full scale was 40 ft span
1/5.3 scale @ 90 inches ;)Warbird Charlie
Mine from back in the day.. I still have it.. built it from the Uravitch plans in 2001. Converted to electric last winter. I wouldn't worry a lot about the cg, anywhere near the spar will work. Super predictable flyer. If you take off without flaps you will need a bit more up elevator input to get it to rotate, due to the trailing link/ aft main wheel location. Mine weighed 17.5 lbs and flew pretty well on O.S 46's. I haven't flown it since converting to electric. You will love it.1 Photo
- Likes 3
Thanks for the info!Originally posted by pullupnow View PostMine from back in the day.. I still have it.. built it from the Uravitch plans in 2001. Converted to electric last winter. I wouldn't worry a lot about the cg, anywhere near the spar will work. Super predictable flyer. If you take off without flaps you will need a bit more up elevator input to get it to rotate, due to the trailing link/ aft main wheel location. Mine weighed 17.5 lbs and flew pretty well on O.S 46's. I haven't flown it since converting to electric. You will love it.
- Likes 2
Ah; I see. My apology. I should have pointed to your "Model Aviation life". I'm hoping that at least that has not had so many rough years....Trial and error maybe, but fun at least.....Originally posted by TiredIronGRB View Post
There were a lot of rough years in it, be careful what you wish for;)
The RC years are great:)Originally posted by AirHead View Post
Thank you!Originally posted by pullupnow View Post80 inch plans with CG notated and the RCU thread
https://www.rcgroups.com/forums/show...81-Bronco-plan
STILL WAITING for the maiden Bro ;) Don't make me have to come down there and do it for ya :PLOLWarbird Charlie
- Likes 3
