Originally posted by Spitfire4life
View Post
Hangar: Mig 29 "Cobra", 8S EuroFighter-Bronze Tiger, A-10 Arctic, F18 Canadian & Tiger Meet, 8S F16 Wild Weasel, 8S F4 Jolly Rodgers & Blue Angel, 1600 Corsair & Spitfire, B-24, Stinger 90, Avanti. Extreme Flight-FW-190 Red Tulip, Slick 60, 62" Extra 300, 62" MXS Heavy Metal, 62" Edge Demonstrator. FMS-SU-30,1700mm P-51, Corsair, Viper, Beast Bi-Plane 60", P2 Bi-Plane, P51.
Bonjour à tous.Cockpit enfin terminé. Je n'ai pas pu insérer toutes les pièces que j'ai imprimées. L’intérieur du Corsair n'ai pas vraiment au 1/8ème. Le pilote est un peu plus petit, pour pouvoir l’insérer à l'intérieur.
Petit problème de peinture, pour faire les retouches. Impossible de trouver la bonne teinte dans mon secteur. A plus, Christian.
Le pilote semble un peu petit, mais je ne suis pas inquiet. Les couleurs de peinture que nous avons assorties au magasin Home Depot. Vous pouvez prendre le morceau de queue de votre Corsair afin qu'ils puissent scanner les couleurs.
riche
Originally posted by redbarn View PostIf you look closely you probably will recognize 3 or 4 items on my Hellcat. Thank goodness for the Flightline Corsair and her parts to help make this Hellcat look much better. Haven't flown it yet but hopefully soon, and then we'll know for sure if it likes this setup.
Tom
Am I the only one who’s ESC get very warm or down right hot? After 2 batteries it is very hot to the touch, I fly at or little over 1/2 throttle. I will admit it seems to get hotter & faster at low speeds such as doing touch & go.
My air temp is about 77 to 83 F. not that hot but with the humidity lately it feels much warm.
Ken
Originally posted by I-fly-rc-aircraft View Post
How's the clearance for the prop? Looks to be minimal.
Tom
Originally posted by I-fly-rc-aircraft View PostDid the tri-color scheme on my D Variant and also some weathering. Kinda proud of the results being my first attempt at such an undertaking.TomI solemnly swear to "over-celebrate" the smallest of victories.~Lucky B*st*rd~
Originally posted by paladin View Postthis may be more work than you want but I would take the servo apart and see which gear is stripped. its usually the gear attached to the output shaft, and the fubar'ed teeth will be on one end, cause the door was open. I would pull the gear off the pot and inspect it, looking for only 3 or 4 teeth that are damaged. if so turn it so it only uses the good teeth and push it back down. if teeth don't go all the way around the out put gear you cant do this.
Joe
Originally posted by downwindleg View Post
Good idea Joe but, unfortunately, there is a slot in the shaft that gear sits on that only allows it to sit one way. Guess I'll wind up ordering a pair of these gear door servos in case it happens again.Platt: fw190d9 Dynaflite:PT-19 IMP:Macchi202 ESM:fw190 ESM:Tank, Hien Jackson:DH-2 BH:macchi200 Extr:fw190 Holman:me109F H9spit2 FL:F4u,spit 9 FW:me262 GP:us60, Stuka, cub, F4u PZ:me109, albi EF Hurri, T-28 FMS: 2x fw190, me109 Lone Star:Skat Kat RSCombat:2xfw190d9
Originally posted by Elbee View Post
Tom, Your paint is outstanding, Sir. Which manufacturers' colors did you use for your Tri-Color livery? I had chosen Model Master match for ANA 806 and 808, (Non-Specular & Intermediate Blue) or vice-versa, I think. I am not at home for a few more weeks, so I can't look to see. Anyway, your colors look great. Best, Steve
I used the Behr paint from Home Depot. Their white and an intermediate blue shown in a previous post.(post 3221). I airbrushed the intermediate blue but used a regular paint brush for the white.
I will tell you this. After putting three coats of white on over the dark blue I had to add 5 oz of weight to the nose plus the two extra slugs that are included with the plane.
That didn't cut it for me so I stripped all the paint where the white is (it just peels off) and put on only one coat of white which in turn saved me 3 oz of nose weight.
I also mixed some acrylic white and black to make a grey which I airbrushed on.
I used some 220 grit sand paper to remove the blue at the worn areas then sparingly brushed on some aluminum paint.
Still have more to do but been flying it in between mods.
Tom
Tom, It's 2.5 inches sitting on the tail wheel and 1.5 with the tail level. Yeah, it's not a bunch of clearance but should be fine on a nice enough runway. I heard a pilot that flies a Hellcat say that you have to take off and land em on a three point so you don't hit the prop on the ground.
Tom
Thank you Steve. I used the Behr paint from Home Depot. Their white and an intermediate blue shown in a previous post.(post 3221). TomI solemnly swear to "over-celebrate" the smallest of victories.~Lucky B*st*rd~
its plastic and you have drills (probably small and metric) then shoe goo it back on in the new location. its FUBAR now and you have nothing to loose if you FUBAR the drive gear again ( I don't think there is a term for FUBARed twice).
