Curious how much attention you all pay to failsafes.
New failsafe positions are memorized by the receiver each time I bind, correct?
My AR620, AR410 and AR636 manuals say their are 2 types of failsafes: "SmartSafe" and "Preset".
"Smartsafe" will move the throttle to idle and all control surfaces will retain their last position at the time of loss of signal with Tx.
"Preset" will place throttle and all control surfaces in the position that I held them when I bound the Tx & Rx.
If I want to set my failsafe to put the airplane into a holding pattern I would need to set the throttle stick up a bit (say 50%) and hold the aileron stick slightly left or right. I would need to hold them in these positions BEFORE I bind and during binding.
The binding procedure in the manuals for all of my airplanes say that throttle and throttle trim must be set to lowest settings otherwise the ESC will NOT arm.
My takeawy from this is that my holding pattern failsafe idea wont work because trying to bind with the throttle stick at anything above idle position will not arm the ESC and I would not be able to fly.
Am I missing something?
