This is the first P-51 model I have ever bought. Growing up around a bunch or Air Racers I was sick of em. LOL. But I do love park flyers, and this looks like a nice one. You simply can't beat the deal here when you count the free shipping. +1 Motion RC. Argh, can't believe I bought a Mustang. LOL
Best Regards
Woody
Official FlightLine 850mm P-51D Mustang Thread
Introducing the New 850mm P-51D Mustang PNP from FlightLine!
FlightLine and Motion RC have re-imagined the classic P-51D Mustang for 2019 in a beginner-friendly format with accurate styling, gyro-readiness, low operating cost and high fun factor in an easily transportable size! This Mustang features a versatile power system that can use either a 3S or 4S flight battery without needing to change the propeller or ESC. The large battery bay accommodates a wide range of battery sizes, from 3S 1600mAh to 4S 2600mAh. Transition from a 30-60mph 3S Trainer to an 80+mph 4S Racer with a simple five-second battery change!
Optimized as both a slow speed 3S warbird parkflyer and a 4S sportscale racer, the FlightLine Pocket Warbird series P-51D Mustang can also fit a gyro-stabilized receiver such as the Admiral RX600SP 6-Channel DSMX™ Compatible Receiver with Stability Plus Gyro. Easy hand launches are accomplished either overhand or underhand, and balanced wing loading provides precise handling and steady landing characteristics. Say goodbye to precarious nail-biting hand launches - - this Mustang is a breeze to launch with moderate throttle and a firm toss. Separating itself from previous generations of parkflyer warbirds in the sub-900mm class, several design elements increase this Mustang's durability including a long plywood battery plate, reinforced motor firewall, shatter-resistant two-blade propeller, one-piece wing with carbon spar, servo horn protectors, and plastic sheathed underside fuselage to resist scuffs during landing. The overall result is a balanced model that "flies on rails" like a larger aircraft instead of being "pushed around" like a toy.
Like the Freewing ParkJet Series of 64mm EDF Jets, the FlightLine Pocket Warbird Series offers modelers a platform for modification and customization. In addition to the structural preparations outlined above, the Mustang also arrives factory painted in satin silver with two different decal sets. Pilots wanting to apply their own color scheme can do so directly over the factory paint without needing to remove any decals. The decal sets are based off of two potential tail colors if you so chose. The green tail is "The Enchantress", piloted by 2nd Lt William Saks. 457th Fighter Squadron, 506th Fighter Group. Iwo Jima, June 1945. The yellow tail is "Shanghai Lil'", piloted by Ed Linfante, 462nd Fighter Squadron, 506th Fighter Group. For more information please click on the Support tab above.
Product Link: https://www.motionrc.com/products/fl...tang-850mm-pnp
This is the stock livery as it comes out of the box
457th Fighter Squadron, 506th Fighter Group "The Enchantress" (Note: You will need to paint the tail section green)
462nd Fighter Squadron, 506th Fighter Group "Shanghai Lil'" (Note: You will need to paint the tail section yellow)
For additional control precision, pilots can also install a 9g rudder servo inside the fuselage and use the pre-molded passageway to guide a control rod rearward toward the rudder hinge itself. The model can be raced within smaller flying fields areas with a lightweight 3S 1600 battery, or in larger areas with a heavier and more powerful 4S 2600. We recommend the 3S 2200mAh or 4S 2200mAh as an ideal balance between flight duration, top speed, vertical performance, and ease of launch/landing.
Backed by Motion RC's world-class service and a host of spare parts, race your Mustang with confidence!
VIDEOS:
Flight Review
Build Video
FEATURES:- Versatile 3S/4S battery capability
- Decal sheet depict both "The Enchantress" and "Shanghai Lil" from the 506th Fighter Group
- 60+ mph (3S) to 90+ mph (4S) top speed
- Gyro-ready
- Beginner-friendly wing loading
- Upgrade-friendly components and layout
- Durable structural enhancements
- Skid-proof underside covering
- Screw-on one-piece wing
- Multiple decal options included
- FlightLine P-51D Mustang 850mm (33") Wingspan - PNP
- Motor, ESC and servos pre-assembled
- 4 Channel radio - select a minimum 4 channel radio from our Radio Collection
- 4 Channel receiver - select a minimum 4 channel receiver from our Receiver Collection
- 3 Cell 11.1V 1600mAh to 4 Cell 14.8V 2600mAh LiPo battery with XT60 Connector – we recommend the Admiral 2500mAh 4S 14.8V 30C LiPo Battery with XT60 Connector
- 4 Cell compatible battery charger - select a minimum 4 cell (4S) charger from our Charger Collection
AGE LEVEL : 14 AND UP
SKILL LEVEL : INTERMEDIATE
BUILD TIME : 1 HOURModel Scale 1/13 Scale Wingspan 850mm / 33.5in Length 740mm /29.13in Empty Weight 510g / 17.98oz (w/o battery) CG (Center of Gravity) 80mm (3.14") from the leading edge of the wing at the root Power System 3S-4S 2836-950kV Brushless Outrunner Motor Electronic Speed Control 30A, XT60 Connector Propeller / EDF 9x6 2-Blade Propeller Servos 9g plastic gear standard with 300mm lead : left aileron, right aileron
9g plastic gear standard with 200mm lead : elevatorLanding Gear None Required Battery 3S 11.1V 1600mAh to 4S 14.8V 2200mAh LiPo with XT60 connector (required) Required Radio 4 Channel (required) Ailerons Yes Elevator Yes Rudder No Flaps No Lights No Hinge Type Nylon Reinforced Material EPO Foam Skill Level Intermediate Build Time 1 Hour Recommended Environment Outdoors Tags: None
