Aileron Servo Movement in FW AT-6
  • tom_pixel
    • Jun 2013
    • 5
    I was setting up some differential in my ailerons and I found right ail would only move up 12 mm and left Aileron 10 mm UP. With travel adjustment max'd out - this is the Max that I could obtain . I have no idea of what the suggested up and dwn amts would be ?? nothing in the manual .
    Rudder and Elev are fine - just very little movement in Ail servo's.
    I have never run into servo's that would not move anymore , than the ones in this wing ??
    ...........te
  • Marco Polo
    Go NAVY
    • Aug 2012
    • 620
    • Illinois
    Re: Aileron Servo Movement in FW AT-6
    Tom,
    When you have large control surfaces like the ailerons on the AT-6 it doesn't take too much deflection to initiate a bank or a roll with the plane. That being said, if you want more movement in the servo you can check the setting on your radio to make sure you have full travel, and you can also make linkage changes on your servo horns and control horns to maximize movements. If you want to increase the movement on any control surface follow this simple guideline - 1) move your clevis towards the innermost hole on the servo horn and 2) move your clevis towards the outermost hole on the control horn. Please use these settings with caution because it will give you a significant amount of control surface movement, and some smaller servos may be damaged by the increased torque/pressure placed on them during sudden turns or high speed flight. Test the various settings and find out what is right for you. I always recommend using the middle servo horn hole and outer control horn hole when starting out.
    Hope this helps,
    Mark
    • tom_pixel
      • Jun 2013
      • 5
      X-Mailer: Microsoft Office Outlook 11
      Thread-Index: Ac54RGzfjTHnwtr0R16xkrjZzfMGqQAEENaA
      X-MimeOLE: Produced By Microsoft MimeOLE V6.1.7601.17609
      X-SA-Exim-Connect-IP: 216.33.127.81
      X-SA-Exim-Mail-From: tom.eutsler@charter.net
      X-SA-Exim-Scanned: No (on joe.nabble.com); SAEximRunCond expanded to false
      This is a multi-part message in MIME format.
      ------=_NextPart_000_0092_01CE7835.0A54EA20
      Content-Type: text/plain;
      charset="us-ascii"
      Mark ,
      Thanks for the info :-) I learned long ago the physics of the horns and
      servo arms , lower hole on one and outter most hole on the other , to get
      the greatest
      amt of movement
      My concern on this plane , with travel Adj max'd out - one servo moves very
      little in comparison with the other . I usally set up the higher amt of thro
      in a surface
      then set low rates at 70 % and start with that - til I see how the plane is
      going to react But I have not found any suggested thro's for this plane
      I'm going to do some more looking at the left ail servo- as it only moves a
      few degrees in either direction - Not comfortable taking it to the field
      with such little
      travel :-)
      Oh, the one wing bolt down in the TE of wing, screw would not go , turns
      out the metal part in the foam was ?? x 'd so I bought a 4 mm tap, thinking
      I cud straighten the threads out ? wrong, the part in the foam just went
      round and round so that did not work . Much to my dismay, will have to use
      some thick CA on that side of the plane while squeezing fuse and wing
      togeather til it sets up
      _____
      [mailto:ml-node+s1075610n493h67@n5.nabble.com]
      Sent: Wednesday, July 03, 2013 7:24 PM
      To: tom_pixel
      Subject: Re: Aileron Servo Movement in FW AT-6
      Tom,
      Hope this helps,
      Mark
      _____
      If you reply to this email, your message will be added to the discussion
      below:
      http://motion-rc-customer-service-forum.1075610.n5.nabble.com/Aileron-Servo-
      Movement-in-FW-AT-6-tp492p493.html
      To unsubscribe from Aileron Servo Movement in FW AT-6, click
      <http://motion-rc-customer-service-forum.1075610.n5.nabble.com/template/Naml
      Servlet.jtp?macro=unsubscribe_by_code&node=492&cod e=dG9tLmV1dHNsZXJAY2hhcnRl
      ci5uZXR8NDkyfC0yMDg2NjE1NDY4> here.
      NAML
      Servlet.jtp?macro=macro_viewer&id=instant_html%21n abble%3Aemail.naml&base=na
      bble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace
      -nabble.view.web.template.NodeNamespace&breadcrumbs =notify_subscribers%21nab
      ble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21n
      abble%3Aemail.naml>
      Content-Type: text/html;
      charset="us-ascii"
      <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
      <HTML><HEAD>
      <META content=3D"text/html; charset=3Dus-ascii" =
      http-equiv=3DContent-Type>
      <META name=3DGENERATOR content=3D"MSHTML 9.00.8112.16490"></HEAD>
      <BODY>
      <DIV dir=3Dltr align=3Dleft><SPAN class=3D959362001-04072013><FONT =
      color=3D#0000ff=20
      size=3D4 face=3D"Kristen ITC">Mark ,</FONT></SPAN></DIV>
      color=3D#0000ff=20
      size=3D4 face=3D"Kristen ITC"></FONT></SPAN>&nbsp;</DIV>
      color=3D#0000ff=20
      size=3D4 face=3D"Kristen ITC">&nbsp;Thanks for the info :-)&nbsp; I =
      learned long ago=20
      the physics&nbsp; of the horns and servo arms&nbsp; , lower hole on one =
      and=20
      outter most hole on the other , to get the greatest </FONT></SPAN></DIV>
      color=3D#0000ff=20
      size=3D4 face=3D"Kristen ITC">amt of movement </FONT></SPAN></DIV>
      color=3D#0000ff=20
      color=3D#0000ff=20
      size=3D4 face=3D"Kristen ITC">My concern on this plane&nbsp; , with =
      travel Adj max'd=20
      out - one servo moves very little in comparison with the other . I =
      usally set up=20
      the higher amt of thro in a surface</FONT></SPAN></DIV>
      color=3D#0000ff=20
      size=3D4 face=3D"Kristen ITC">then set low rates at 70 % and start with =
      that&nbsp; -=20
      til I see how the plane is going to react&nbsp;&nbsp; But I have not =
      &nbsp;found=20
      any suggested thro's for this plane ??</FONT></SPAN></DIV>
      color=3D#0000ff=20
      color=3D#0000ff=20
      size=3D4 face=3D"Kristen ITC">I'm going to do some more&nbsp; looking at =
      the left=20
      ail servo- as it only moves a few degrees in either direction - Not =
      comfortable=20
      taking it to the field&nbsp; with such little </FONT></SPAN></DIV>
      color=3D#0000ff=20
      size=3D4 face=3D"Kristen ITC">travel :-)</FONT></SPAN></DIV>
      color=3D#0000ff=20
      color=3D#0000ff=20
      size=3D4 face=3D"Kristen ITC">Oh, the one wing bolt down in the TE of =
      wing,&nbsp;=20
      screw would not go , turns out the metal part in the foam was ?? x =
      'd&nbsp; so I=20
      bought a 4 mm tap, thinking I cud straighten the threads&nbsp; out ?=20
      wrong,&nbsp; the part in the foam&nbsp; just went round and round&nbsp; =
      so that=20
      did not work . Much to my dismay, will have to use some thick CA on that =
      side of=20
      the plane&nbsp; while squeezing fuse and wing togeather til it sets up=20
      </FONT></SPAN></DIV><BR>
      <DIV dir=3Dltr lang=3Den-us class=3DOutlookMessageHeader align=3Dleft>
      <HR tabIndex=3D-1>
      <FONT size=3D2 face=3DTahoma>From: Mark [via Motion RC Customer =
      Service=20
      Forum] [mailto:ml-node+s1075610n493h67@n5.nabble.com] <BR>Sent:=20
      Wednesday, July 03, 2013 7:24 PM<BR>To: =
      tom_pixel<BR>Subject: Re:=20
      Aileron Servo Movement in FW AT-6<BR></FONT><BR></DIV>
      <DIV></DIV>Tom, <BR>When you have large control surfaces like the =
      ailerons on=20
      the AT-6 it doesn't take too much deflection to initiate a bank or a =
      roll with=20
      the plane. &nbsp;That being said, if you want more movement in the servo =
      you can=20
      check the setting on your radio to make sure you have full travel, and =
      you can=20
      also make linkage changes on your servo horns and control horns to =
      maximize=20
      movements. &nbsp;If you want to increase the movement on any control =
      surface=20
      follow this simple guideline - 1) move your clevis towards the innermost =
      hole on=20
      the servo horn and 2) move your clevis towards the outermost hole on the =
      control=20
      horn. Please use these settings with caution because it will give you a=20
      significant amount of control surface movement, and some smaller servos =
      may be=20
      damaged by the increased torque/pressure placed on them during sudden =
      turns or=20
      high speed flight. &nbsp;Test the various settings and find out what is =
      right=20
      for you. I always recommend using the middle servo horn hole and outer =
      control=20
      horn hole when starting out. &nbsp; <BR><BR>Hope this helps, <BR>Mark=20
      <BR><BR><BR>
      <HR color=3D#cccccc SIZE=3D1 noShade>
      <DIV style=3D"FONT: 12px tahoma,geneva,helvetica,arial,sans-serif; =
      COLOR: #444">
      <DIV style=3D"FONT-WEIGHT: bold">If you reply to this email, your =
      message will be=20
      added to the discussion below:</DIV><A=20
      href=3D"http://motion-rc-customer-service-forum.1075610.n5.nabble.com/Ail=
      eron-Servo-Movement-in-FW-AT-6-tp492p493.html">http://motion-rc-customer-=
      service-forum.1075610.n5.nabble.com/Aileron-Servo-Movement-in-FW-AT-6-tp4=
      92p493.html</A>=20
      </DIV>
      <DIV=20
      style=3D"MARGIN-TOP: 0.4em; FONT: 11px/1.5em =
      tahoma,geneva,helvetica,arial,sans-serif; COLOR: #666">To=20
      unsubscribe from Aileron Servo Movement in FW AT-6, <A=20
      href=3D"http://motion-rc-customer-service-forum.1075610.n5.nabble.com/tem=
      plate/NamlServlet.jtp?macro=3Dunsubscribe_by_code&amp;no de=3D492&amp;code=
      =3DdG9tLmV1dHNsZXJAY2hhcnRlci5uZXR8NDkyfC0yMDg2NjE 1NDY4">click=20
      here</A>.<BR><A style=3D"FONT: 9px serif"=20
      plate/NamlServlet.jtp?macro=3Dmacro_viewer&amp;id=3Dinst ant_html%21nabble=
      %3Aemail.naml&amp;base=3Dnabble.naml.namespaces.Ba sicNamespace-nabble.vie=
      w.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&amp=
      ;breadcrumbs=3Dnotify_subscribers%21nabble%3Aemail .naml-instant_emails%21=
      nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml"=20
      rel=3Dnofollow>NAML</A> </DIV></BODY></HTML>
