Hi All: I just got my new F4U Corsair from Flightline. It all went together pretty well, no problems there. However I have a big problem with the rudder and tailwheel and steering, (or lack of it). Wonder if anyone has any ideas what I might be overlooking or doing wrong. Haven't seen this issue before on other planes.
When the gear is up, the rudder functions normally, no problem. But when I put the gear down, that's when the "fun" begins. The gear cycles normally up and down and when the gear is down, the tailwheel doesn't respond to any control inputs to move left or right. Also, when the gear is down, the rudder now does not respond to any control inputs and actually is moved about 30 degrees off center and freezes there.
I have a Spektrum 18 and a Spektrum receiver which I think is working ok. Does anyone any ideas on a fix?
Thanks so much, Davegee
