Legends P-38
  • CT
    • May 2014
    • 294
    Legends P-38
    I am completing my 2100mm  P-38 project and preparing for maiden. Does anyone know where the CG should be? Unable to locate on RC Groups and J&B wont respond.
    Thanks, Chris
  • doctormike
    HobbySquawk Moderator
    • Oct 2013
    • 1260
    • Santa Fe NM
    RE: Legends P-38
    Most CGs are about 1/3 of the cord back from the leading edge. Then, go for slightly nose heavy to be on the safe side. You can adjust trim on the maiden, and then move your battery accordingly. Be sure to center your trim after the battery adjustment. Good luck!! Doc
    • CT
      • May 2014
      • 294
      RE: Legends P-38
      Thanks Doc., I have so many hours into this build I wanted to confirm with the Mfg., but looks like I will have to use the proven method.
