1700 P51D FMS Prop Angle
  • Rickster
    • Nov 2015
    Had to pull the motor on mine. Does anyone know how to obtain the best prop angle for this plane?? Pic's would also be helpful
    Thank You :s
  • Jack
    • 17
    Hi Rick. I could be wrong but I am pretty sure the angle is built into the motor board that the motor x bracket is bolted to. Right angle and down thrust. I just did a motor upgrade to mine with a Leopard 5065 390kv motor and was faced with the same ?'s. Unless you are missing the motor board, I think you'd be ok with just mounting the motor back to the original board. Hope this helps.........Jack
    • Flyer Phill
      Roo's on the strip again!
      • 82
      • Brisbane, Australia
      Thank You :s
      The thrust angle is set in the firewall. You don't have to do anything other than bolt the motor in.
