T-28 retract and flap issues
  • 3090kilo
    • May 2019
    I have the T-28 with flaps and retracts. I recieved the airplane as a gift. I found out later, that everything works except for the flaps and ailerons. The servos have been replaced, reminded it and yet they still don't work. I need help and advice.
    • 8834
    There are several brands and sizes of T-28. It might be helpful to say which one you have. Before you put the new servos in, did you put them on a servo tester to check them out first? If not, you should at least yank the leads out of the receiver and use a servo tester on them while in the plane. If that doesn't work, then you need to go to the first connection just before the servo and test it there. Only in this way, can you narrow it down to where the fault might be. Self diagnosis is the best way to attack this problem. Asking on a forum will not give you the final answer but point you in the direction that you should pursue.
