Need a bigger battery. Whats out there
Champ s+. Need a bigger battery
You'll have to look at a few sources and measure what will fit.
There are many 2S LiPos availabe that would be fine for current delivery and capacity. The question is weight, physical size and getting it in place for CG.
From MotionRC, minor increase in capacity.
Plenty of choices in the 300 to 400 mah range from other sources.
You might have to make an adapter or change plug on the ESC E-Flight likes to use a heavy duty balance plug on their 2S mdels. This causes issues with finding or making adapters to use a decent charger.FF gliders and rubber power since 1966, CL 1970-1990, RC since 1975.
