Official Dynam DHC-2 Beaver 1500mm Thread
    • 8205
    (Click here for the PNP version and here for the RTF version product pages).
    The de Havilland Canada DHC-2 Beaver is a single-engined, high-wing, propeller-driven, STOL aircraft developed by de Havilland Canada, primarily known as a bush plane. It is used for cargo and passenger hauling, aerial application (crop dusting and aerial topdressing), and has been widely adopted by armed forces as a utility aircraft. The United States Army purchased several hundred; nine DHC-2s are still in service with the U.S. Air Force Auxiliary (Civil Air Patrol) for search and rescue. The Beaver was designed for flight in rugged and remote areas of the world. Its short takeoff and landing capability made it ideal for areas normally only accessible by canoe or foot. Because it often flies to remote locations, often in cold climates, its oil reservoir filler is located in the cockpit and oil can be filled in flight.
    Take to those rugged lakes and ponds close to your personal wilderness with Dynam's 1500mm (59") PNP DHC-2 Beaver! All you need is a 5 channel radio, 5 channel receiver and 4S 14.8V 2200mAh Li-Po battery and you're ready to master those water-based environments less traveled! Or if you prefer land-based operation, the DHC-2 Beaver also comes with landing gear.
    FEATURES:
    • NEW! Now comes with operational flaps
    • Realistic scale features including DHC-2 paint scheme and molded panel lines
    • Set of floats with operational rudders for water takeoffs/taxiing and landings
    • Powerful BM3720A-KV650 Brushless Outrunner motor
    • Fixed landing gear included for land-based operation
    • LED navigation lights add scale realism and help make the plane more visible during dawn and dusk flights
    INCLUDES:
    • Dynam DHC-2 Beaver 1500mm (59") Wingspan - Receiver Ready
    • ESC with XT60 connector, servos and motor come pre-installed for your convenience
    • Set of regular landing gear
    REQUIRES:
    • 5 Channel Radio - Select a minimum 5 channel radio from our Radio Collection
    • 5 Channel Receiver - Select a minimum 5 channel receiver from our Receiver Collection
    • 4 Cell 14.8V 2200 mAh LiPo Battery with XT60 connector - EPR22004X6
    • 4 Cell Compatible Battery Charger - Select a minimum 4 cell (4S) charger from our Charger Collection
    Click image for larger version  Name:	dynam-dhc-2-beaver-with-gyro-1500mm-59-wingspan-rtf-motion-rc-827702116377_1024x1024.jpg Views:	0 Size:	97.8 KB ID:	196840
  • Rodney Benjamin
    • Aug 2019
    • 4
    any One else having a problem getting the battery in the battery opening? I can get it thru the door but not up inside we’re it’s supposed to go? Do I have to put it in thru the wing saddle every time? Came as a ready to fly kit with a zippy 2200 battery
