Can carbon cub S RTF transmitter bind to other BNF
  • Winggo
    • May 2019
    • 7
    I bought a Horizon Carbon Cub S RTF with the Spectrum DXe transmitter a while back. I just ordered the Parkflier F4E Wildcat BNF. Can I bind the DXe to the F4E?
    • 8814
    The only Wildcat I know of in the "F" series is the "F4F". What specific brand and model did you actually buy? Is it a Parkzone or other Horizon Hobby product? If it is and it's Spektrum equipped, then yes, it will bind. Read the manual for the DXe and it should tell you what's involved with the set up of this TX. If you use it for another Spektrum compatible BNF plane, you will likely need to do a little programming to get things to work correctly. Do you have the programming cable or Bluetooth dongle?
