Dynam F4U Corsair 1270mm Prop Spinner Hub
  • Shywolf
    • Dec 2015
    • 10
    I ordered this plane early Jan 2016 newest shipment, the Alum Spinner Hub is the wrong size (diff threads) for the prop shaft. I contacted Motion RC and they already knew this was an issue and was told the new shipment from Dynam would be correct, this is not the case. If you order this plane and the Hub will not freely spin up to the prop then its the wrong one. mine would get only a turn or two and then catch. Motion RC has a ticket in for me to get an adapter sometime in February. i wish i would have known this i would have ordered a different plane for now.
    [hr]
    im kinda shocked Motion RC knew of this problem and still sell them with no replacement (fix) with the order or some kind of notice. I may have damaged the motor the prop shaft has a little burr on it from me trying to hold it. i know dumb idea.
  • fhhuber
    • Aug 2015
    • 1476
    RE: Dynam F4U Corsair 1270mm Prop Spinner Hub
    Takes a LOT of force to ding these motor shafts...
    But it shouldn't be an issue if you didn't bend it.
