XK A1200
  • Tooeleflyboy
    CS Agent
    • 508
    XK A1200
    Recently received this plane for testing and review and it is a very interesting aircraft. So simple to put together and there is no wires to plug in. As you assemble the control surfaces they just plug into small connectors for the servos. The radio is computer controlled so I was able to add more expo for my liking. Used -50 on the elevator and also was able to program some travel limits for down elevator as it was to much stock and would pitch down sharply. Put -30 on the ailerons and rudder headed to the park in 15mph winds, set the gyro to 6G mode gave some throttle and tossed her! very nice flight and a great plane for beginners. In 3G mode it is very stable even in the winds and you can build some confidence with this bird. Lands very slowly with no bad stall characteristics. CG seems right on the money with the stock battery installed.
