I have a A-10 it came with 70mm turbines can I replace with 80 mm and if so will I have to make any changes to electronics thanks for any help
Change
You should tell us what brand of A-10 you have. Sounds to me you have either an FMS A-10 or one of the older LX model. Maybe someone has done such a conversion if you gave more detail. However, in general, putting an 80mm fan in a nacelle that's made for a 70mm fan isn't going to be easy. You have to have enough material in the nacelles to ream it out 5mm all around. Then you need ESCs that will be able to accommodate the type of 80mm fan/motor you choose. Just asking if you can put in an 80mm fan isn't much to go on since there are several options you can choose from and each one has its own type, size and kv of motor, # of blades and each one can require a different size of ESC.
