I just purchased this arf from general hobby ($289!)to transfer everything from a crashed skyline slick. Both are well constructed and the covering is perfect. Kits come with tank and quality hardware. The downside is that the only manual available is a fits all for the 30cc line of arfs. Anyone flying one of these that i can get a working cg from? Info on the web is very sparse. My default plan is to start at the back edge of the rather large diameter carbon spar.
Skyline 30cc 74" raven.
RIP.. roc hobby waco,strega #2(you will be missed), Fw 90mm eurofighter.Tags: None
I'm in the process of building the same plane which I picked from a. Local flyer. Not my first plane but it is my first gassed. I'm not ready to start balancing yes but have been doing some reading on it. I read a post on FlyIng Giants and the suggested the CG was 140 mm from the leading edge of the wing. Another post suggested CG at the front edge of the wing tube. Like I said I have not gotten to that point yet to confirm. Someone inexperienced started building the plane so I'm having to correct several building errors. But, I like to build so it is a go project for me.
Originally posted by MobileRaptor View PostI'm in the process of building the same plane which I picked from a. Local flyer. Not my first plane but it is my first gassed. I'm not ready to start balancing yes but have been doing some reading on it. I read a post on FlyIng Giants and the suggested the CG was 140 mm from the leading edge of the wing. Another post suggested CG at the front edge of the wing tube. Like I said I have not gotten to that point yet to confirm. Someone inexperienced started building the plane so I'm having to correct several building errors. But, I like to build so it is a go project for me.
