Aeronca Champ
  • F22trainer
    Finally, I got a video for ya…
  • F22trainer
    Originally posted by Alpha
    The tension on those flying surfaces are really well built. Great job! Woody would be proud.
    Big thanks - I’ll try and get a video, but it has to be a calm day for her to come out!
  • BluesDragon
    Wow.. that looks fantastic! Very nice work there, Michael
  • F22trainer
    Finally got around to the finished photos Click image for larger version
ID:	317648Click image for larger version
ID:	317649Click image for larger version
ID:	317650Click image for larger version
ID:	317651Click image for larger version
  • F22trainer
    2 flights - first was a surprise a la ‘Spruce Goose’ taxi test with a lift off. Took more throttle than I expected to get it moving, but figured I would find out how it handled on the ground. First downwind at half throttle for a few seconds - stayed nice and straight so I swung around into the wind and slowly brought it up to about the same throttle point - rolled about 30’ and noticed it was already off about an inch and smooth straight flight. So, what the heck and I let it climb. Well, she’s a bit tailheavy and a real floater. I t was also seriously under powered, with the 8x4 prop that came with the brush motor which I did not use. Went up to a 9x6 speed prop giving better results.
    Sorry, no HatCam video - I thought it was charged.
ID:	260945Click image for larger version
  • F22trainer
    F22trainer Any progress updates? It looks seemed like you were fairly close to the painting stage?
    While the preceding photos were taken last night as the windshield adhesive set up, as of tonight she is airworthy. All up weight with 1300 mAh 3S is 22.7 oz. while probably not necessary I added 0.6oz in the nose as CG was right at the aft limit.
    Hat Cam video to follow...:star_struck:
  • F22trainer
  • F22trainer
    Finally! Enough free time and light workload to get the silver dope sprayed on. Final assembly coming soon.
  • F22trainer
ID:	254469 I did take these showing a pretty good aileron fit, smooth tension on the silk, and the wing strut ends fitted.
    B4E5A7A0-356D-4AA8-8363-9CCD5A0D3269.jpegClick image for larger version  Name:	54EAED20-C176-4B65-8D76-C7F077DE159E.jpeg Views:	0 Size:	67.6 KB ID:	254467
  • F22trainer
    Glad you asked - it seems I have hit the build stage for clear dope to coincide with a vendor shortage...probably should have gone with Stits. But no, I wanted to do it old school. I ran out of clear before I finished the wing, but everything else has been coated with clear 2x and sanding sealer 2x. Need another coat of clear on the wing top surface and then sanding sealer. I am more than ready to start getting silver on this bird. Even got the AS3X programmed for 3 modes. I mean everything is done except the silver. I’ll order the Graphics from Callie as soon as I get the clear underway again. Windows are all cut and trimmed pushrods, linkages, and clevis’s are all set. Even got the pilot painted. Once he silver is ready to go down, I am on the fence about either staying with butyrate dope silver or polyurethane silver - I have both and the sprayer is cleaned and ready. I may just pick up another tank of compressed air from the welding supply instead of the compressor - so much quieter.
  • F22trainer
    Waiting for the last of back ordered Sig Dope, that shipped earlier this week. Managed to create an instrument panel from a web photo. Need another coat of clear and then sanding sealer on the wings. All the other fuselage and miscellaneous parts are ready for the silver.
  • F22trainer
    A glimpse of another prop machine in the work shop, with my dad in front of his - Da Nang, 1966 Click image for larger version
  • F22trainer
    Originally posted by BluesDragon
    Looking good there, Michael! I'm fairly confident she's gonna be a beauty.. can't wait to see it in the air.
    From one Stealth Mod to another - Thanks!
  • BluesDragon
  • F22trainer
    Always seems once the wing starts getting covered, you feel like the home stretch begins.
  • F22trainer
    Tried to find some finished examples of this kit, with only ONE video posted on UToob...
    nearing completion now.
  • F22trainer
ID:	249297Click image for larger version
ID:	249298Click image for larger version
ID:	249299Click image for larger version
ID:	249300 Fortunately able to work from home! Did squeeze some time over the weekend to start covering the Airknocker...
  • F22trainer
ID:	241004Click image for larger version
