Elevator stick
  • Smudge123
    • 13
    Elevator stick
    Just set up my dyhnam f4u corsair I'm new to all this lol everything is good apart from when I pull back the elevator stick they go down not up all video's I've watched elevator shud go up or am I wrong thanks in advance
  • Sekhet
    If it has wings, I'll give it a fly!
    • 107
    • New Martinsville, WV
    sounds like you need to go into your transmitter and reverse your elevator servo direction.
    Best regards,
    Cris B.
    AMA#L945841, NASA#2845, JPO#2503,
    NSRCA#4603, IMAC#7357
    • Smudge123
      • 13
      How do u do that mate
      • Sekhet
        • 107
        What brand and model of transmitter are you using?
        In most transmitters you would go into the servo settings to change the direction of an output.
        Best regards,
        Cris B.
        • Smudge123
          • 13
          This is what I'm using cheers
          • Smudge123
            • 13
            Is it this that I use to reverse elevator stick if so which channel do I change pps can I still fly the plane without changing anything cheers
            • Sekhet
              • 107
              You need to reverse the channel that controls your elevator.
              Ensure that your stick movements give you the correct control output on the aircraft. (Elevator stick back = elevators Up, Rudder stick left = rudder left, Aileron stick right = Right aileron goes up.
              Best regards,
              Cris B.
              • Smudge123
                • 13
                Ye cheers mate all sorted now phew lol
                • Sekhet
                  • 107
                  Outstanding!
                  I hope you have a lot of fun with her.
                  Best regards,
                  Cris B.
                  • Smudge123
                    • 13
                    What's the best battery for the dynam corsair f4u v2 12700mm cheers
                    • Sekhet
                      • 107
                      I would go with an Admiral 2200mAh 4S 14.8V 35C LiPo Battery with XT60 Connector.
                      Best regards,
                      Cris B.
                      • Smudge123
                        • 13
                        Cheers
