Greetings from the PNW,
I recently purchased the Flight line 1600mm Corsair. I'm very happy to say the least. I can run FLAT OUT for 7 minutes straight on the Admiral 6s 6000mah pack and land at 3.75 volts per cell, and up to 10 minutes with throttle management with ease. Now that I'm used to it, looking for a power upgrade. I HAVE THE NEED FOR SPEED!!! I'm hearing about the Flightline 1600mm Spitfire motor is the ticket. Cant find any info in the official Flightline 1600mm Corsair forum. Here are the claims ---- Plug and play direct fit --- No prop change required --- Better climbing power --- Faster straight line line speed --- Flight times are about the same --- No ESC change required. Are these claims true? I found motor specs for the Spitfire, But no listing for motor specs on the Corsair. I would like improved performance for sure, But I would really like a screaming 4 minute motor at 95mph to 100mph as well. Who's got answers?
I know of 3 RC Aircraft that DO NOT used the 80% rule. Hobby King Grand Tundra draws 78 amps on 6s using a 80 amp rated ESC. You can check Youtube on that one. My FMS P40 War Hawk drew 67amps on 4s using a factory 70 amp rated ESC. I swapped it out for an 80 amp ESC to maximize the safety factor. So yes I have read what your talking about, its been a long time since I've heard anybody talk like you, and it took a minute for this old guy to remember. I worked in the auto industry for 35 years.Electrical was my favorite.
