Super Decathlon 2450mm (96.4") Wingspan from Black Horse - Balsa Wood ARF - BHM1006-001
The American Champion 8KCAB Decathlon and Super Decathlon are two-seat fixed conventional gear light airplanes designed for flight training and personal use and capable of sustaining aerobatic stresses between +6g and −5g.
Black Horse's RC model is scaled to approximately 1:4 scale and attention was paid to a true to original appearance and best flight characteristics. The model can be operated using an electric power system or a gas or nitro power system.
Visit the Official Black Horse Super Decathlon 2450mm Discussion Thread on HobbySquawk.com for additional photos, videos, reviews, and customer Q&A.
Visit the Official Black Horse Super Decathlon 2450mm Discussion Thread on HobbySquawk.com for additional photos, videos, reviews, and customer Q&A. ![]() |
Detailed Cockpit A detailed cockpit and painted pilot adds to the realism and scale appeal. An opening door reveals the detailed instrument panel and false floor that conceals other electronics. |
| Fiberglass Molded Cowl The one-piece painted cowl requires minimal adaptation to your preferred power system. |
Gas or Electric Power You can choose between gas or electric to power your model depending on your preference. |
| Scale Details The Decathlon sports several scale details and functions including opening cabin doors and metal braces. Clear molded plastic windows and windscreens enhance the realism and provide a view into the detailed cabin, including painted internal bracing structures. |
Vibrant Paint Scheme The model comes with a bold and beautiful red and white paint scheme that is highly visible. Its airfoil is carefully selected for class "high-wing" flight characteristics, with a very mild stall, high lift, and stable behavior. |
- High level of prefabrication right out of the box
- Lightweight, strong, laser cut balsa and plywood construction
- ~1/4 Scale
- Panel lines and details printed directly onto the pre-applied, high quality covering
- Aerofoiled tail surfaces
- Recessed hinges on all control surfaces
- Pre-drilled hinge mounting holes
- Heavy-duty pin hinges on all control surfaces
- Large easy access fuel tank/battery/servo access hatches with sprung loaded latches
- Painted and detailed cockpit, pilot and interior included
- Fiberglass control horns with ball link connector
- comprehensive control and fitting accessories included
- Two-piece, plug-in wings simplify transportation and assembly
- Fiberglass cowl and glass reinforced landing gear covers/pants
- Mounts for both electric and gas power options included
- Black Horse Super Decathlon 2450mm (96.4") Wingspan - ARF
- 6 Channel radio - select a minimum 6 channel radio from our Radio Collection
- 6 Channel receiver - select a minimum 6 channel receiver from our Receiver Collection
- 1100-1600 Watt brushless outrunner motor - we recommend the Admiral GP10 5030-400kV brushless motor
- 60-100 amp brushless ESC - we recommend ZTW Gecko 85A ESC with 8A SBEC with XT-60 Connector
- 5x 45g standard servos - we recommend HS-311
- 6 Cell 22.2V 4000mAh LiPo Battery with XT60 connector - we recommend Admiral 4000mAh 6S 22.2V 40C LiPo Battery with XT60 Connector
- Electric propeller - we recommend APC 14x8.5 Thin Electric Propeller
- 6 Cell compatible battery charger - select a minimum 6 cell (6S) charger from our Charger Collection
