Freewing P-51D HP "Old Crow" 1410mm
  • DadsRcHangar
    RC Pilot
    • Feb 2020
    • 26
    • United Kingdom
    Hi all,
    anyone had this problem, if so what did you use to stick the loose servo down with?
    Chris
    DRCH
    • 8749
    I use FoamTac. Clean off as much as possible, of the original white glue from the servo first. Use a razor blade being careful not to slice into the wires.
    • Prowler901
      • 940
      • Gunnison, CO
      Some FoamTac will hold that. Alternatively, low temp hot. glue will also work well.
      • DadsRcHangar
        RC Pilot
        • Feb 2020
        • 26
        • United Kingdom
        Thank you, wanted to make sure. Will give it a go.
        Chris
        • PappaBear
          • May 2015
          • 377
          • California
          FoamTac is the best glue for gluing foam. It stays flexible and will move with the foam. Epoxy or any hard setting glue will break at the joint because it can't flex.
          • DadsRcHangar
            RC Pilot
            • Feb 2020
            • 26
            • United Kingdom
            Will do thank you. Nice that you was with a real Old Crow.
            Chris
            • PappaBear
              • May 2015
              • 377
              • California
              I can only claim to have stood in front of the Old Crow and NOT flown it.
              PappaBear
              • Gil
                • May 2018
                • 6
                One of my retracts, the servo has stripped. Has anyone had a luck getting replacement?
