Curious if the fw190 landing gear will work on the fw190 dora??
Flightline Fw190 Dora will fw190 langing gear work with this 850mm warbird??
Tags: None
All Fw190 versions shared the same landing gear. You just need the correct scale. 850mm is pretty small so finding "190" gear with the correct angle that small will be tough. But, a straight leg gear wouldn't look so bad on a model that small. I think eflight made the smallest "Fw190" 74degree retracts ( EFLG115 ) but they would be awfully big. The FlightLine 1120mm Fw190 landing gear may be a little smaller than the eflites but would still be big.
