Posted this in RCGroups as well
Also posted on the Razorback thread in the Warbirds section.
Ok, so an eventful morning!
First flight went good. Fought the sun coming in and landed just to right of runway. Not a stellar start!
Second flight, (after checking to ensure the off field first landing didn’t mess anything up). Took off and noticed I had trouble with my right turn out. Added a bit more aileron and that’s when I noticed I had no aileron control! It was flying away toward the highway. So, I immediately powered back and put full left rudder. She actually turned quite nicely on rudder only. Added a bit of power and made a complete 270* turn back toward the field, tho off one end of the runway. Cut power and made an off field landing. Farmer had harvested the alfalfa so I had plenty of open area. Checked every thing and had full control!
Third flight. Took off and immediately lost aileron again! Made a 180* with rudder only and reverse direction landing. This time, I had limited elevator as well! Again off field....sigh!
As we were standing over the airplane watching all the controls act normally, I looked down to ensure my throttle cut off was engaged. That’s when I noticed my SAFE select was engaged. I don’t fly with SAFE. It did not “limit” bank angle....it deleted it! Changed switch setting and flew normal.
I have SAFE on switch G (DX8 Gen 2). With 0 being engaged and 1-2 being off. Settings are 100/0/-100 respectively. Do I need to change the 100 to -100 in case I accidentally toggle that switch again? I’m really surprised it cancelled out any inputs!
Ideas?
Ideas?
