Here we go again, another Cub plane, only it is Electric, big, and made from balsa and spruce instead of foam.
The Nexa Piper PA-18 Super Cub is a .46-size electric scale series civilian aircraft with a 1620mm wingspan, constructed primarily from balsa wood and fully covered. This ARF requires assembly and installation of your choice of servos and power system, and includes a two piece wing design with aluminum wing joiner, fiberglass cowling, detailed cockpit, working cockpit doors, dummy engine, a large battery hatch and pre-hinged and installed control surfaces.
• 5 Channel radio - a minimum 5 channel radio
• 5 Channel receiver - a minimum 5 channel receiver
• Brushless outrunner motor
• 85 Amp brushless ESC
• 4x high torque micro servos for ailerons, rudder and elevator
• 4 Cell 14.8V 4500 - 5000 mAh LiPo Battery
• 12x8 Electric propeller - we recommend an electric 12x8 (wood is more scale)
• 4 Cell compatible battery charger - a minimum 4 cell (4S) charger
I have decided to order this plane as I like the NEXA L4 Grasshopper so much, and I am sure this model is built from the same jigs in a similar format.
