Dynam messerschmitt
  • Chris curran
    • Aug 2020
    • 215
    Dynam messerschmitt
    Does anyone have the dynam ME 109? I'm looking to rake the gear forward. Has anyone done this, and if so, How?
  • vdanger
    Major Danger
    • 144
    • Oswego, Il
    Chris, I've raked the gear forward on several warbirds, both Dynam and other brands (not a ME 109 however). I put thick plastic washers under the rear two mounting screws of the retract mounting plate. That will angle the strut forward and usually still allow it to retract in the stock wheel well. If you have to use several washers, you might need to use longer mounting screws for the rear.
    Good luck!
    Super Airliner, Corsair, Viper, BAE Hawk, L-39, A-6, PC-21, B-25, T-28, GeeBee, Wildcat, Stinson, F-16, F-4
    • Chris curran
      • Aug 2020
      • 215
      Thanks man. I'll give that a try. I was concerned about if the gear would retract back into the stock wheel wells.
      • Chris curran
        • Aug 2020
        • 215
        I tried that, But the Gear is set deep in the wing, so. I didn't dare. I just flew it as is. Man, What a docile bird.
