Still scratching my head.......... Any ideas anyone? Brand new. Blew up on the ground.
Catastrophic failure of motor mount P51D Old Crow
Prop balance as well as tracking. If one or more blades wasn’t seated properly and wasn’t tracking true, prop imbalance or compromised (cracked) spinner backplate could all be culprits in this type of failure.
new spinner, prop blades and some glue and you should be back in business. Or order a new fuselage....
I'd go with this. Each blade needs to be weighed and made to be exactly the same weight. Then the back plate needs to be balanced, in addition to the spinner.Originally posted by timmybeetle View PostHi
Looks like an unbalanced prop assembly.
Did you check balance of spinner and prop?????
Grts Hans
