sport cub s 2
  • hawk22
    • Nov 2020
    sport cub s 2
    I have sport cub s 2 which motor does not work anymore. I replaced motor with new one and throttle comes on full as soon as I put battery in. (No, it is not issue with motor cable being reversed) Weird thing is if I connect original motor (which is not working) onto battery directly, it ran!
    very confusing. It is definitely an issue with the board I think but very strange... after all, I would not expect receiver problem to cause it to turn on motor as soon as battery is connected. any one had same issue?
    • 8824
    "Motor cables" ....................... You don't really reverse those. By changing a couple of the 3 wires, you simply reverse the direction of spin on the motor. However, have you checked to see if the "throttle" on your TX hasn't been reversed? That's in your servo reverse menu.
