Hello friends - Im seeking wisdom from the experts on the Extra 300 set up.. I am not new to planes but have little exposure to the AS3x receiver. So is this correct? I set up the plane flight surfaces to zero and made sure my DX9 does not have any trim or sub-trim. All throws are at 100%. I assigned switch A for my stability mode and regular mode. I then went in and adjusted the manual mode as follows: Ail: 55/55 Elev: 65/65 Rudd: 70/70 D/R High 100% / Mid 70% / Low 50%. Ia also dialed down GEAR to 70/100. My intentions are to have a easy flyer than can bump up (via D/R) to some acrobatics and when in stability mode have increased control - the stock Ail rate gave it a huge circle. Does this sound OK - haven't flowing with these settings and understand more micro adjustments may be necessary. Appreciate any thoughts or info you my offer me..
Seeking Wisdom
