Official ZOHD 1000mm SonicModell Talon GT Rebel - PNP Thread
  • jbaartz
    • Sep 2020
    • 481
    SonicModell Talon GT Rebel 1000mm (39.37") - PNP from ZOHD - ZOH10045
    The Talon GT “Rebel” is the continuation of ZOHD's new series called MKII, started with the highly acclaimed Dart XL “Extreme”. This series will feature an incredible set of high quality and ORIGINAL innovations, intended to give you the FPV aircraft for casual, mid and long range.
    With MKII, without cutting any corners, they went straight ahead with 100% biodegradable and environmentally friendly materials, metal gear servos, high-quality power plants, protection for leading edges and skids, wing fences, vortex generators, dedicated bays for FPV gear, revolutionary multi-cam hard noses and much, much more.
    Talon GT is one of the most capable FPV-ready planes regardless of wingspan and price. Can compete in range and speed with planes twice as big and twice the cost. Specifically designed to fly with modern flight controllers, high power video transmitters and long-range systems, Talon GT will give you the best FPV experience to date. Easy assembly, setup, and maintenance… A true king of the skies!
    Easy Assembly and Transport
    The detachable wing and vertical fins makes the Talon GT Rebel easy to transport.
    Forward-Thinking BEPP Construction
    The Talon GT Rebel is molded using 100% biodegradable EPP (BEPP), built-in CF spar for enhancement, stable flying capability and impact resistance.
    Large Battery Bay
    The Talon GT Rebel incorporates a large battery bay for your chosen FPV equipment and electronics.
    Camera Compatibility
    The multi-camera nose is compatible with 99% of the FPV and HD cameras in the market: Runcam HD, 2, 3S, Swift, Split, GoPro H4-5-6-7, Session, and much more!
    FEATURES:
    • Thanks to its revolutionary design, the plane performs and looks like no other in the market
    • Small size airframe optimized for long range and portability with cutting-edge production technologies
    • Carefully chosen airfoil gives the aircraft an incredible lift power and excellent handling in any circumstances
    • Detachable wing and tail make it portable for easy transport
    • Familiar V tail layout, easy to set up
    • ZOHD’s exclusive BEPP material isn’t only crash resistant, but 100% biodegradable
    • Lightweight composite hard nose for better protection of your expensive camera gear
    • Multi-camera nose: Compatible with 99% of the FPV and HD cameras in the market
    • Reversed wingtips, provide more lift force and ensure an efficient wing surface
    • Carefully engineered wing fences
    • Reinforced pushrods for better overall performance and safety
    • Load it as much as you want due to the large equipment bay
    • Computer designed optimized air flow pod that maximizes cooling, reducing the risk of crashes for overheated electronics. No more DIY foam cutting!
    • Impact resistant protective cover for main wings leading edge and belly will keep your plane away from wear and tear
    • Built-in carbon fiber spar inside main wings for enhanced performance and rigidity
    • Built-in carbon fiber square rod reinforcement all along the fuselage
    • Exclusive VTX / RX bays with excellent airflow and away from interference
    • U-stand for comfort and convenience while setting up the plane
    INCLUDES:
    • ZOHD SonicModell Talon GT Rebel 1000mm (39.37") - PNP
    REQUIRES:PRODUCT SPECIFICATIONS:
    AGE LEVEL : 14 AND UP
    SKILL LEVEL : INTERMEDIATE
    BUILD TIME : 1 HOUR
    Wingspan 1000mm / 39.3in
    Length 660mm / 25.9in
    Weight (w/o battery) N/A
    CG (Center of Gravity) Refer to manual
    Power System 2216-1300kV Brushless Outrunner Motor
    Electronic Speed Control 40A
    Propeller / EDF 8x5
    Servos 9g metal gear
    Landing Gear N/A
    Required Battery 4 Cell 14.8V 3000-3300 mAh LiPo Battery (required)
    Required Radio 4 Channel (required)
    Ailerons Elevons
    Elevator Elevons
    Rudder Yes
    Flaps No
    Lights No
    Hinge Type Foam
    Material BEPP Foam
    Skill Level Intermediate
    Build Time 1 Hour
    Recommended Environment Outdoor
