SonicModell AR Wing 900mm (35.4") - PNP from ZOHD - ZOH10002
This AR Wing with a detachable main wing/wingtip structure, it’s compact size and pre-installed power system makes it very easy to assemble and portable for outdoor FPV flying. The high strength EPP material with built-in carbon fiber tube and strips makes it rigid and crash-resistant and the 9g digital servos will ensure it flies accurate and agile.
Easy Assembly and Transport The detachable wing and wing tips makes the AR Wing easy to transport. |
| Durable, Impact-Resistant The AR Wing is molded in durable EPP, built-in CF spar for enhancement, stable flying capability and impact resistance. |
Large Battery Bay The AR Wing incorporates a large battery bay for your chosen FPV equipment and electronics. |
| Glue-Free Assembly Glue-free assembly so it's mere minutes from opening the box to flying. |
- Black EPP molded wing and fuselage, plus pre-built in carbon fiber spar, durable, light and flexible
- Detachable wing and wingtip, portable and easy to transport
- Multiple bonus camera mount, compatible for all FPV HD cameras on the market
- Extra bottom plastic cover to protect the fuselage, extra plywood wingtip for VTOL flying
- Fiberglass canopy hand grip for strength and durability
- Enhanced main wing with plywood and screws to avoid breaking off in a crash
- Easy to hand launch, super stable flying performance
- Wingspan 900mm with high-efficiency airfoil creates a powerful elevating force
- “No-glue” required assembly, head to the flying field in minutes
- Same motor / ESC / prop / camera as many racing quads
- Spacious equipment bay for more FPV gear
- Movable battery slot for better “CG” adjustment
- CG mark "bumps" under the main wing for convenience
- 2 skids for hand launch grip and landing
- "NACA" Air inlet and outlet for FPV gear cooling
- ZOHD SonicModell AR Wing 900mm (35.4") - PNP
- 4 Channel radio - select a minimum 4 channel radio from our Radio Collection
- 4 Channel receiver - select a minimum 4 channel receiver from our Receiver Collection
- 3 Cell 11.1V 1500 - 2200 mAh LiPo Battery - we recommend the Admiral 2200mAh 3S 11.1V 35C LiPo Battery with XT60 Connector
- 3 Cell compatible battery charger - select a minimum 3 cell (3S) charger from our Charger Collection
AGE LEVEL : 14 AND UP
SKILL LEVEL : INTERMEDIATE
BUILD TIME : 1 HOUR
| Wingspan | 900mm / 35.4in |
| Length | 482mm / 18.9in |
| Weight (w/o battery) | N/A |
| CG (Center of Gravity) | Refer to manual |
| Power System | 2204 2200kV Brushless Outrunner Motor |
| Electronic Speed Control | 20A |
| Propeller / EDF | 6x3 |
| Servos | 9g metal gear |
| Landing Gear | N/A |
| Required Battery | 3 Cell 11.1V 1500-2200 mAh LiPo Battery (required) |
| Required Radio | 4 Channel (required) |
| Ailerons | Elevons |
| Elevator | Elevons |
| Rudder | No |
| Flaps | No |
| Lights | No |
| Hinge Type | Foam |
| Material | EPP Foam |
| Skill Level | Intermediate |
| Build Time | 1 Hour |
| Recommended Environment | Outdoor |
