A-24 Banshee 1540mm (60.6") Wingspan - ARF from Nexa - NXA1018-001
The Douglas SBD Dauntless is a World War II American naval scout plane and dive bomber that was manufactured by Douglas Aircraft from 1940 through 1944. The SBD ("Scout Bomber Douglas") was the United States Navy's main carrier-based scout/dive bomber from mid-1940 through mid-1944. During its combat service, the SBD proved to be an excellent naval scout plane and dive bomber. It possessed long range, good handling characteristics, maneuverability, potent bomb load, great diving characteristics from the perforated dive brakes, good defensive armament, and ruggedness. One land-based variant of the SBD – omitting the arrestor hook — was purpose-built for the U.S. Army Air Forces, as the A-24 Banshee.
The Nexa A-24 Banshee is a .46 size electric or gas option scale series warbird with a 1540mm wingspan, constructed primarily from balsa wood and covered with a fuel-resistant covering. This ARF requires assembly and installation of your choice of servos and power system, and includes flaps, painted pilot, machine gun, antenna and other scale details. The large battery hatch affords ample room for either electric or gas setups. To complete the scale appeal of this beautiful A-24 Banshee, the model includes electric retracts and scale struts. Impress at your flying field with this iconic stunner!
Fully Covered and Detailed The Nexa A-24 Banshee comes fully covered including simulated panel lines, rivets, nomenclature and weathering detail. |
| Scale Details Throughout There is no shortage of scale details with this A-24 including functional and distinctive perforated split flaps, antenna, machine guns, painted pilot, electric retracts and metal main struts. |
Prehinged and Installed Control Surfaces All control surfaces come out of the box fully prehinged and installed for your convenience. |
| Sized Right, Easy To Transport The A-24 at just over 1500mm wingspan marries ease of transport while still having a nice presence both static and airborne. |
- Complete Balsa and lite-ply construction for rigidity and durability
- Covered from tip to tail in scale details including weathering, functional perforated split flaps, printed simulated panel lines and rivets
- Fiberglass cowling for strength and durability
- The hand-painted pilots are ready for your added cockpit details
- All control surfaces come out of the box pre-hinged and installed for convenience
- Flaps, antenna, guns and more complete the fantastic scale appeal
- Large battery hatch allows for your chosen electric or gas setup
- Nexa A-24 Banshee 1540mm (60.6") Wingspan - ARF
- Electric retracts, wheels and struts
- Fuel tank, hardware and servo trays
- 7 Channel radio - select a minimum 7 channel radio from our Radio Collection
- 7 Channel receiver - select a minimum 7 channel receiver from our Receiver Collection
- Brushless outrunner motor - we recommend the Admiral GP10 5030-400kV Brushless Motor
- 65 Amp brushless ESC - we recommend the ZTW Mantis 65A ESC with 5A SBEC
- 4x standard servos for ailerons, elevator and rudder - we recommend FOUR Hitec HS-425BB Deluxe Ball Bearing Plastic Gear Standard Servo
- 3x standard servos for flaps - we recommend THREE of the Hitec HS-81 Micro Servo
- 6 Cell 22.2V 4000 mAh LiPo Battery - we recommend the Admiral 4000mAh 6S 22.2V 40C LiPo Battery with XT60 Connector
- Electric propeller - we recommend APC 15x8 Thin Electric Propeller - Black
- 6 Cell compatible battery charger - select a minimum 6 cell (6S) charger from our Charger Collection
- 2 or 4 stroke (.46 - .70) engine
- 2 blade gas propeller (size depends on engine)
Nexa ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine).
PRODUCT SPECIFICATIONS:
AGE LEVEL : 14 AND UP
SKILL LEVEL : INTERMEDIATE
BUILD TIME : 6+ HOURS
| Model Scale | 1/8 |
| Wingspan | 1540mm / 60.6in |
| Length | 1060mm / 41.7in |
| Weight | 3200g / 112.87oz |
| CG (Center of Gravity) | 92-96mm from the leading edge of the wing's root |
| Power System | 400kV Brushless outrunner motor for electric or 2-4-stroke for gas (required) |
| Electronic Speed Control | 65A (required) |
| Propeller / EDF | 15x8 2-blade for electric (required) |
| Servos | 45g metal gear standard: left aileron, right aileron, elevator, rudder 9g metal gear standard: left flap, center flap, right flap |
| Landing Gear | Electric retractable (included) |
| Required Battery | 6 Cell 22.2V 4000 mAh LiPo Battery (required) |
| Required Radio | 7+ Channel (required) |
| Ailerons | Yes |
| Elevator | Yes |
| Rudder | Yes |
| Flaps | Yes |
| Lights | No |
| Hinge Type | Nylon |
| Material | Balsa and light plywood |
| Skill Level | Intermediate |
| Build Time | 6+ Hours |
