Hello all,
Just picked up a Freewing Pandora 4 in 1 and will probably be taking it out for its maiden in a week or so. This'll be my first powered plane and the first time flying in about 20 years.
We did the initial assembly last night and got to the point where we needed to determine deflection/rate of control surfaces. I'll be flying with my brother who has about a year of experience flying. He has a ROC Hobby MXS and said that the assembly instructions that came with that plane had a section that showed how to set deflection of control surfaces. The Pandora does not have instructions on how to do this. My bro said that if you set your control surfaces to deflect at maximum for the full travel/swing of the gimbals in the transmitter the plane might respond too much or too quickly and be difficult to control for a beginner.
Now the MXS is a sport/stunt plane and has ailerons the full length of the wing which makes them very responsive. The Pandora only has ailerons half that length so maybe setting deflection of the ailerons is so critical.
Does anyone have experience with setting up a Pandora prior to initial flight? Is it important to set up deflection on this plane or should I just run it at maximum?
Also my radio is a FlySky FS-i6. This adjustment on the radio is called rate.
Thanks for any input
