850mm P51
  • CRambo17
    • Jan 2021
    • 6
    850mm P51
    How do I remove elevator and aileron servos? I’m learning!! Lol
  • SanExup
    • 912
    • Western Wy.
    Is the plane you are taking them from being saved? You can slice around the edges but be careful of the wires, they exit the servo.body from the side of the servo. If you look at a photo of a servo theh almost always exit the housing from the same side. Ince you slice you probably have to pry the glue bond from the back of the servo. It should come off with fairly little effort.
    • CRambo17
      • Jan 2021
      • 6
      Thank you! I’ll try that.
