Horizon Hobby Sport Cub S V2 RTF With SAFE Flap issues
  • barrycuda
    • Apr 2021
    • 2
    We had a crash and broke the motor mount for the propeller had no problem gluing the part back on but we must have done something wrong when we hooked up the wing flaps to the receiver. Because now both flaps operate at the same time in the same direction. Can't find a manual that shows where to plug things in. HobbyZone Receiver/ESC Unit: Sport Cub S v2 (SPMA3178) - HOBBY ZONE. If I did hook it up correctly then I have no idea what happened. Any ideas?
    • 8824
    This plane has no flaps. It only has ailerons. If you plugged the ailerons into the flap port, it's not going to work. They have to be plugged into the AIL port.
    • barrycuda
      • Apr 2021
      • 2
      i did not pay enough attention when we unplugged the wires. Do you happen to have a diagram or picture that shows the correct connections?
        • 8824
        No, I don't have this plane. Try downloading the manual for it or go to the parts section and look at the RX to see what plugs into where.
