Carbon S2 Aileron problem
  • Markburn30
    • May 2021
    I'm a beginner and had my maiden flight yesterday. I had an encounter with some tree branches. No structural damage but had a crash landing. My left aileron won't go back to the "normal" position. I can move it there manually, but when I plug the battery in it goes to full "down" position. All other elevator, rudder, right aileron are ok. I tried disconnecting the aileron connection and recconecting. Also tried binding the connection again. All seems normal, I get the rudder wag, but the left aileron continues to go the the full "down" position. Any suggestions?
    • 8824
    In the crash, it’s likely the aileron got pushed forcefully and this resulted in the servo to ratchet past a bunch of teeth or even strip a lot of teeth. Only way to fix it is to replace the servo with an identical one. If you can’t find an identical one, then you’ll have to buy 2 new servos of the same size and replace both aileron servos.
