I just purchased a Carbon Cub. I have flown it about 9 times. The other day the strangest thing happen to the plane. While I had the plane in Advance mode, I tried to do a loop and I could not do it. The day before the advance mode was working just fine. So I re bind it and nothing changed. So I then deleted the plane and started all over with the new settings. Still nothing has changed. Any suggestions before I call Horizon.
Carbon Cub safe mode.
Tags: None
This is a long shot, but next time you fly in advanced mode, release the sticks and see if the plane self levels.
If it self levels, the “panic button” might be activated. This could be due to it being assigned to a switch which you’ve accidentally thrown. Or, the switch might be faulty, whatever.
.png)
