Flaps
  • Captain Pappy
    Captain Pappy
    • May 2021
    • 13
    Flaps
    Has anyone installed flaps on their Carbon Cub.
  • Navy Flyer
    • Aug 2022
    I've installed flaps in two of mine (one on wheels and one on floats), plus several more for other newer guys. They work great, however....If you have the Carbon Cub S2, you can not use the airplane type as 1 aileron/one flap in order to set up the flap programming. That blocks Aux 1 and the 3 flight modes no longer work. If you set up the wing type to NORMAL, the 1 flight modes work. Green, Blue, and Red lights on the windscreen. To make flaps work, you can program AUX2 for flaps and assign to normal 3-position flap switch D, then make the adjustments through the Servo Setup screen. Next you have to do a mix from flaps to the elevator to obtain the offset for up pitch when the flaps are deployed. You can also set the servo speed from the Servo Setup screen. It is a royal PITA compared to how it should be, but it will work. It is not nearly as easy as it is to program from the normal Flap System screen. In a chat with HH tech service, they only regurgitated the settings in the manual, but those do not work.
