I'm about to stuff a DJI Digital HD FPV Air Unit into my Cat. I'm thinking of mounting it under the canopy with the camera through the center of the windscreen and an o-ring gasket. The Air Unit will be secured as far back as I can get it. So both will be suspended up high away from water. The thin plastic canopy, intended to be glued on the front hatch, will be secured by screws instead of glue for access. (It's a sea plane, right?) I'm also going to slip the GPS antenna under the forward gun turret.
Anyway, I would like to hear your thoughts on the idea and would be grateful if you could give me any info on the following:
1. What would be the best way to power the Air Unit? I've heard it should be regulated to prevent power spikes. Is that an issue?
2. I've heard the antennas on the Air Unit have a right and left orientation and should not be swapped left to right. Is that true?
3. I understand the Air Unit gives off a lot of heat. I was thinking of using a small fan under the Air Unit with a drain and a vent at the back of the canopy. Do you think this would do the trick?
I cannot believe the adaptability of this airplane!
