Loctite
  • PappaBear
    • May 2015
    • 377
    • California
    Loctite
    We are often asked about the use of Loctite, especially with plastic parts. Please be aware that Loctite is NOT recommended for use where it may come into contact with plastic parts. Please see the link below. You will see this is a Loctite product and it clearly states not recommended for use on plastic. Blue Loctite will react with the plastic, and the parts will fail. This goes for any of the plastic parts in any of models supplied by Motion RC.
    If you really want to lock a part in place, use Foam Tac. This is more than adequate for securing nuts and bolts on a foam model. Electric models are not subjected to anything like the same level of vibration as that of a glow or gas engine.
    Martin.
    Good topic, Martin. We hear at least twice a month of someone using Loctite on plastic. Metal screws into the propeller, for example. That Loctite corrodes the plastic propeller backplate and you can guess what happens on the maiden flight. I'm quick to point out that even on a metal to metal joint, for example on the Strega's wing bolts, where a metal machine screws threads into a threaded metal receiver, there is still the risk of Loctite oozing out and touching the plastic mount that molds that threaded metal receiver. I've seen where the screw remains in the threaded metal receiver, but the threaded metal receiver itself pops right out of the corroded plastic mount. Goodbye, wing!
    The bottom line is, never use Loctite anywhere near plastic, period. It isn't worth the risk, even if it's only close but not actually touching. Foam Tac is a good alternative. But personally I've never used any additional screw fixative on a foam electric fixed wing aircraft.
    • doctormike
      HobbySquawk Moderator
      • Oct 2013
      • 1260
      • Santa Fe NM
      Thanks for the warning. I'll be using E- 6000 now if the screws are anywhere near plastic, which is most of the time. Doc
      • farmflyer
        • Mar 2015
        • 1164
        • Quitaque Texas
        I hadn't thought about using foam tac for this but it makes good sense. I think I'll be using it more for basically all of my gluing and thread lock on all applications in the future except for the occasional use of hot glue.
        • Teeks
          Warehouse Wizard. MotionRC CS
          • 46
          • Chicago, IL
          Great advice Martin. I've seen many of the ugly results of Loctite on plastic parts and it isn't pretty.
          • Dewey H Lee
            WARBIRD JUNKIE
            • Apr 2015
            • 919
            • Fayetteville NC. US
            Thank you Martin. I'm a retired machinist and just have a question for on the loctite. Can you apply loctite and allow it to dry and then install set screws ect. We use to do this a lot in the experimental machine shop. Most of our set screws were going in aluminium and plastic. The cured loctite still held the fastener even after drying. Please advise. Thank you.
            Dewey l
            • boomer108
              Chief Boom
              • Apr 2014
              • 868
              • Chicago IL.
              Hey everyone!
              I recall reading about a guy complaining about the wing coming off his Waco because the cabanes came loose. He said he couldn't figure out why the screws came loose because he used loctite on them!! Bad stuff on plastic. I've used Welders adhesive with great success which is the same as Foam Tac which I also use on foam and plastic.
              Roy B.
              • owyheeguy
                • Aug 2015
                • 30
                • Marsing,Idaho
                If you have already done it is there a fix?
                Always fly in the middle of the air and stay away from the edges. Edges of the air are identified as trees, ground, water, buildings, etc.
                • boomer108
                  Chief Boom
                  • Apr 2014
                  • 868
                  • Chicago IL.
                  That depends one what part or area your talking about on the plane.
                  • fhhuber
                    • Aug 2015
                    • 1476
                    there is a commercial version loctite made for this... Normal doesn't work correctly this way.
                    Note... the "cured" loctite still attacks plastic.
                    Once the loctite has been applied to the plastic its too late. Its a chemical reaction that makes the plastic brittle. Its going to crack.
                    • Konrad
                      Banned
                      • 733
                      • San Francisco
                      As to the plastic nothing, the loctite damages the plasticizer particularly thermo plastics. So the parts need to be replaced or reinforced. Some times you can remove the damaged plastic and use a threaded insert. But often there isn't enough wall thickness to allow this.
                      I damaged the elevator horn on my Splendor and had to come up with this fix (fiberglass plate) or spend another $20 on a replacement part.
                      • Konrad
                        Banned
                        • 733
                        • San Francisco
                        Loctite is a brand name. They make and market a wide variety of compounds. I assume we are talking about anaerobic thread lockers.
                        As they are anaerobic they don't dry (oxide or evaporate) to cure. There are cleaners and primers that help with the curing in certain material. (copper in the alloys really helps, some of these primers have a .2% copper sulfate compound for this) But as it has been noted these thread locking compounds will fail most (not all) plastics, particularly thermo plastics.
                        • Konrad
                          Banned
                          • 733
                          • San Francisco
                          I'm thinking that this might be better placed in tips & tricks.
                          • owyheeguy
                            • Aug 2015
                            • 30
                            • Marsing,Idaho
                            Good morning Boomer108. there are tiny screws attaching the plastic wing struts to the wing on my J-3 Cub. I think I'll coat those areas with epoxy. I don"know if the struts are functional of just cosmetic on this model.
                            John N.
                            • Konrad
                              Banned
                              • 733
                              • San Francisco
                              What brand and model of the cub?
                              • boomer108
                                Chief Boom
                                • Apr 2014
                                • 868
                                • Chicago IL.
                                John N.
                                I would think they are functional to give some some rigidity from vertical movement,but not knowing the plane that's just an educated guess.
                                • owyheeguy
                                  • Aug 2015
                                  • 30
                                  • Marsing,Idaho
                                  Hi Konrad, it's a Hobby King J3 Cub, 55" wingspan.
                                  • StormyDog1962
                                    • 338
                                    • Naperville Illinois
                                    Clear nail polish is a good option, simple to apply and gums up the threading to keep them screws from backing out. Tiny bottle stores easily just be careful your buddies don't see it in your flight box. Might start talking about ya!! Use clear as Pink raises too many questions!!
                                    • fhhuber
                                      • Aug 2015
                                      • 1476
                                      Careful with nail polish and plastics... They generally use acetone based paint for nail polish. This can attack some plastics.
                                      • boomer108
                                        Chief Boom
                                        • Apr 2014
                                        • 868
                                        • Chicago IL.
                                        Hey Guys!
                                        Use Foam Tac or Welders adhesive. It doesn't hurt foam so it won't hurt plastic.
                                        Roy B.
